jdm 1 piece fog light help!
[SIZE=“5”]how do i wire up my foglights to go on the same time as the corners instead of the headlights?[/SIZE]
TEG TIPS> First, find the red/yellow wire in the FOGS switch. Cut this wire about 2" away from the switch. make sure to cover up the live wire that u wont be using. take the 2 inchs that come from the switch… attach a wire to that and run it to ur fuse box the fuse box has several free power sources if u search a little bit u can find witch one is Hot with ACC(has power when ignition is on.) u just crimp on a plug and plug her into the proper socket. make sure to put a fuse on the new foglight wire. preferably the same resistance and the oem fuse for the fogs i did this a long time ago so im a little scratchy on it. just search man ull find it.
