JDM 1 Piece Install step-by-step
Okay, so you got those JDM 1 Pieces you always wanted. Not too many pic step by steps out there hu? Well here ya go.
Step 1:
Eww… USDM, gotta get rid of that!
Step 2:
These lights are old. I suggest you use some black silicon around the edges to seal up the lights just in case…
Step 3:
If the rubber seals on the edges are coming off, black silicon can seal them up against the light as well. Once all siliconed up, leave lights to dry a bit
Step 4:
Clean those lights off with something like windex or whatever, then pick up a bottle of meguire’s Plastx, clear plastic polish and go to town on the lights. It’s easier to do it while they’re off the car…
Step 5:
Now we gotta get that bumper off. Start with the 4 bolts shown
Step 6:
Two screws in the wheelwell come off as well.
Step 7:
Remove the bumper signal lights and note the 4 bolts behind. Undo these, but before doing that…
Step 8:
You require one of these to help pull it off. A pal who will work for free or for beer.
Step 9:
Three bolts on the top of the USDM Headlights come off, as well as these 2 bolts underneath.
Step 10:
Now we gotta wire these harnesses in. The fogs and peanut bulbs are easy. Black = Ground, Red = Positive, but the headlight…
Drivers Side uses Red/Yellow and Red/Green, Passenger side uses Red/Blue and Red/White. Both use black for ground though… See the legend.
Step 11:
Solder and Heatshrink all connections. Don’t do a twist n’ tape half assed job!
Test each headlight bulb individually. If you havent made any mods, your fogs should go off during high beam, and on during low. If they stay on for some reason, or the headlights seem quite dim, you’ve mixed up the wiring.
Step 12:
Bolt the 1 Pieces in place of the old ulgy USDMs, but before putting the bumper back on, check alignment of the lights by closing the hood. (And to give you a taste of the final project LOL)
Step 13:
Do steps 5-8 in reverse, and sit there enjoying your new look.
Peace!
XtReMe98 & FAWKER
:up: x 100 great job!
very nice, thanx
this is by far the best tutorial i’ve seen for this job! it will definately be useful when I get my new one pieces next week :roll:
Sweet man I’m putting mine in tomarrow. Are the wires simple to hook up?
So simple… just follow the colour code n’ you’ll be fine
Did it like 2 weeks ago very easy
just did mine! they look awesome!! I’ve used 2 Civic 93 harnesses to plug into the lights bulb. Now the only thing I am worried is: how the f*ck do I change a burnt light? and where can I get ultra glowing amber corner lights
viz
Replacing a bulb takes 5 minutes, real easy. (pass side takes longer since you may have to remove the battery)
I’ll show you if you ever need to. BTW, be ready to spend about $100 for new bulbs…
coolio, thanks :slight_smile: and yup i know about the bulbs… every good thing has a (real) bad side :bawl: for now, my h4h work fine… tomorrow is time to go get some plugs for my fogs since my stock were not the same plugs.
viz
I’d recommend getting a spare set of h4h’s now just in case…
just my opinion though…
G2i Head Lights
Where Are The Old Head Lights
IF ANYONE IS SELLING OR GIVING UP THERE OLD HEADLIGHT
EMAIL ME WITH INFORMATION.
GREENLANTERN7709@AOL.COM
Do you need the lamp or bulbs?? Do you need the USDM 3-pc?
In a bag, in the attic, in case i have to go back to stock before selling the car
great thread the wiring info was great
:up:
does the foglights fit in or i have to cut something?
no cutting necessary at all on this project…
xtreme do you have aim? i wanna ask you some noob questions
i have aim… but i never use it… i’m on msn though… xtreme98@hotmail.com
