I bought a set of JDM window visors for my 2door and it doesn’t seem to fit. I’m afraid they sold me a 4 door set of window visors. I don’t have any friends with a 4 door anymore or any friends with window visors to compare with. Can someone help me by measuring the length of their 2 or 4 door visor so I can compare it with mine. I don’t want to start a paypal claim on them if the set is correct. I’m also trying to get an install PDF if anyone has one. Thanks!
just line em up to the windows. if their for the sedan theyll obviously be too long. the coupe visors go past the front door to where it starts to curve down on the side window.
They did look a few inches too long when I lined them up but just to be sure I would like a definative measurement of a 2 door or 4 door.
[QUOTE=Grifter;2156932]They did look a few inches too long when I lined them up but just to be sure I would like a definative measurement of a 2 door or 4 door.[/QUOTE]wana sell them if there for the sedan
from the second screw hole on the front of the visor to the end of the back of the visor is about 36.5 inches long that is on my da an i sport has a pdf file one installing them if you need it
from the second hole to the tip on my db visors is 37". if i’m not mistaken the biggest defferance will be at that bend because the da windows are longer and not as much angle… give me your email, i have the install .pdf from isport as well
Thanks for the reply guys! most eNVy’d- sent you a email about the PDF. If they are 4door visors I may sell instead of doing a Paypal claim.
i got dibs if u sell lmk 8602024982
I could tell you what they are just by a picture. The 4 door ones are slightly narrower and slightly longer (they continue past the rear window on a 2 door and are skinnier on that end). Both basically have the same bend in them.
Here’s pics of some of my 2 door ones (which are for sale):
Also, here’s some pics of 4 door vs. Acura Vigor ones which are the same as 4 door Integra ones just with different clip locations and longer clips… (I think the top two are the Integra ones, but I’m not completely sure since I took the pics 2-3 years ago, but you should be able to see some difference between them and the 2 door ones pictured above… just the clip locations should be a dead giveaway):
Thanks phatcardesignz. Based on the 2 door pics it looks like the 2nd clip is right before or close to the apex bend of the visor where my 2nd clip is located right past the apex. The clips used the on the 2door don’t match what I have. Also the length from the 2nd visor clip to the end is also 37inch as listed by most eNVy’d. Looks like I got jacked.
most eNVy’d-got the PDF! Thanks!
lsjdmteg-i’ll let you know if I sell.
no prob on the pdf, lemme know if you sell aswell, might want another set lol
