Hey guys, I know the differences between the input shaft splines but the thing I’m wondering about was if I already have the clutch and flywheel that was already on the JDM B16 w/LSD would I be able to mate it to my 92 B18A1? I dont have the transmission code as the sticker fell of years ago but I do remember it was a JDM B16 trans. My only issue is that I have no clue if they will mate or not.
JDM b-series trans will require a '90-91 Integra clutch disc. The flywheel/throwout bearing and (i believe) pressure plate will swap over from any '90-01 Integra.
The transmission will bolt directly to the motor.
[QUOTE=unified112;2305933]JDM b-series trans will require a '90-91 Integra clutch disc. The flywheel/throwout bearing and (i believe) pressure plate will swap over from any '90-01 Integra.
The transmission will bolt directly to the motor.[/QUOTE]
depends on the year of the JDM cable b16 if its from 89-91 then it will be the small spline if its a 92 it will be the large spline from all 92-01 B-series.
Also the only diffrence between the two is clutch disk, you can mismatch the pressure plate and flywheel. However the throwout bearing needs to be from a 90-93 integra.
I was under the impression that every JDM b-series took the same clutch disc. Hm.
Thanks for the correction!
So essentially as long as I use the clutch it already has then it will bolt up? But I will need to use the throwout bearing from my LS tranny?
Yes, the clutch that was originally mated to that trans will work. Throwout bearing from either trans will work - they are the same.
If you’re in doubt of what clutch you need, just take the measurements. Smaller diameter shaft = 90-91 clutch ::: Larger diameter shaft = 92-93 clutch
I still have a unused clutch for that transmission, so the clutch isnt an issue. But happy to hear that I wont have an issue swapping it over
just the answer I needed. I have the the small spline but will be swaping to the big spline from a 93. Do you guy still recommend Honda mtf? where the step by step to swap transmission.
Use Honda mtf and I always blend half a quart of lukas gear oil, makes is shift like new. Don’t get the synthetic auto trans stuff, your more likely to leak.
Thanks for the tip. Gonna start this swap tomorrow.
