[QUOTE=billys_da_integ;2201995]u need a b17 powersteering bracket or a jdm b16 xsi power steering bracket from a da9
here is my swap let me know if you have any questions
http://forums.g2ic.com/showthread.php?194601-FINISHED!!!-JDM-B18c-in-93-LS…-PICS!!!-56K-BIG-WARNING!!!&highlight=[/QUOTE]
Ah, perfect. I’m on the hunt for either of these mounts now then. Thanks! I take it you use the LS accessory pulley then, to continue using the v-belt for the power steering?
You should use the whole pump assembly from the LS. Other pumps will have different hose fittings
Actually what I was referring to is the accessory pulley at the crank. Sounds like to use the LS power steering pump, use b17 or b16 xsi bracket and LS crank pulley to maintain the v-belt for PS.
I meant to say the he can use is stock LS ecu to run his swap if for whatever reason his jdm ecu doesnt work. I ran my jdm itr swap with my stock ecu for 2 weeks till i got new ecu. Your just not going to have Vtec. You cant hurt the engine since its still a b18.
I also mentioned to upgrade to 250hp axles since you will only find custome axles hp rate start at 250hp and up.
[QUOTE=da6xsi06;2202225]I meant to say the he can use is stock LS ecu to run his swap if for whatever reason his jdm ecu doesnt work. I ran my jdm itr swap with my stock ecu for 2 weeks till i got new ecu. Your just not going to have Vtec. You cant hurt the engine since its still a b18.
I also mentioned to upgrade to 250hp axles since you will only find custome axles hp rate start at 250hp and up.[/QUOTE]
Actually, it is a bad idea to run a b18c with the b18a ecu. The b18c is higher compression and the maps have different timings. The cam timing are also different between the b18c and b18a.
No one has ever documented the affects of running a b18c on a stock b18a ecu in the long term, so we do not know if any harm can be done to the engine. In the low load and low RPM range you might be able to get away with it, but if you are driving on load and at higher rpm’s there is a potential to damage your engine.
So, I started working on the car today
Now, the swap I picked up comes complete with its original engine harness, etc. I need to know what these wires are for:
to describe what you’re seeing. It is a small group of wires (one red, one green) that are run over top of the intake manifold. Not sure what they are for, but I traced the wires into the main engine harness. Would like to know what they are for. I will NOT be reusing the original wire harness. I will be using my LS wire harness (which is easier to use, anyway) but I want to make sure I know what this goes to so I can ensure everything will plug in correctly.
so, its the IAB control solenoid valve? i’m horrible with drawn diagrams.
if that’s the case, then I don’t need to worry about it. the Rywire VTEC subharness I ordered should take care of that, then.
Nah, I was just being stupid. Here’s the right picture:
Just some unneccessary stuffz
picture helps a bit, but still not sure what it is for.
is it the EVAP purge control solenoid, then? If I recall correctly, that part isn’t even on the motor I have. running without it won’t throw a CEL would it?
Thats pretty much the same thing as the 2 little round sensors that are by your DA’s original map sensor. removing them shouldnt hurt anything
On OBD0/1 cars it won’t throw a CEL.
which driver side axle seal do I need? a new DA seal? got the OEM part number? good aftermarket equivalents? want to get it ordered tonight.
Just look it up at acuraoemparts… the drivers-side axle seal is what you need.
DA or DC? want to make sure before I order.
I believe DA, as the B18C trans would already come with a DC seal.
