JDM B18C swap questions
Okay, guys. I’m about to start the swap, but want to make sure I’ve got all the bases covered here.
The swap is a JDM B18C with LSD trans(SiR-G. NOT Type-R) swap and all components are OBD1. My car is OBD1 as well. I’ve got the harness, etc. covered.
Just need to assure the following:
  1. That the USDM wire harness will plug into the JDM ECU. (The wiring, etc. will not be a problem. Wiring is something I’ve become quite good at in the last few years) I just want to make sure that all the plugs, etc. will snap right in. Again, both the new JDM ECU and my car’s current wire harness are all OBD1. I’ve seen that the case for the JDM ECU is dramatically smaller than the USDM LS ECU, but haven’t been able to compare the plugs, etc. If it plugs right in, awesome. If it doesn’t, I’d like to know now before I get into it and have to order more stuff and delay the finishing of the swap.
  2. That using the USDM LS intermediate shaft and axles will work fine with the swap and factory LSD (swap I bought was without axles, etc.) I’ve read on numerous sites that they’ll work fine with the NON-LSD transmissions, but couldn’t find anything conclusive about the LSD. Just wanting to make sure there aren’t any major differences between them, other than the diff itself.
  3. What radiator hoses do I need? The hoses that came with the swap were cut about 6" short of being usable. Will the hoses from my LS work? I googled like crazy, and 3 different sites said 3 different things, and none of the threads were concluded with a solid answer. If I need to order hoses, I’d like to know now so I can get them ordered, and have them in time before I start the swap. If it helps, the radiator is a 100% factory OEM radiator, straight from the dealer.
  4. Also, will the LS shift linkage work? I’d like to avoid buying another shift linkage, but will if I HAVE to.
Right now, these are my biggest concerns. All other aspects, I feel I’ve got under control. I’ll be sure to ask when the swap is in progress if I run into anything.
As usual, ladies and gentleman, any and all help is appreciated.
You haven’t gotten this thing in yet? :stuck_out_tongue:
As far as your questions go…
  1. Yes you’ll be fine with your JDM ecu, other than not being able to mount the same as your old PR4.
  2. No problems with your stock axles and half shaft (although if they’re still the old stockers, I’d pick some new ones up from Raxles. Can’t help to replace those while you’re at it). But you’ll have to grab a new driver’s axle seal since the DA half shaft is a different size (40x56x8 for the DA and 35x56x8 for the DC). Having the LSD won’t make a difference, just be sure to use the right fluid
  3. Not really sure, but what about DB2 hoses?
  4. Stock shift linkage will be fine, but it’s old as shit and will have some slop in the u-joint. You can always just buy a new lower linkage from the dealer for the u-joint, and then get some poly bushings for the other parts too. That’s what Carl is doing: http://forums.g2ic.com/showthread.php?201224-Carlitos-SoCo-build-thread&p=2188181&viewfull=1#post2188181
    Now that your questions are answered, hurr up! :slight_smile:
  1. yes your jdm ecu should snap right in and if the engine doesnt crank then you can always use your LS pr4 ecu, run your itr swap as an LS and no vtec.
  2. On the subject of axles then you need to address your engine mounts first and get innovative /hasport for your year to make sure your engine is lined up correctly, if its not then your going to have improper axle wear and issues. You will need to use your current or newer half shaft and axles until you can get custom 250hp axles, and you can use good old honda manual trans fluid from honda or acura dealers and they work fine with the lsd.
  3. You can use your current rad hoses only thing needed is trimming off about 3" or so for the top hose to fit snug.
  4. Need to get a new shift rod like mentioned above since yours is most likely old and sloppy, the entire rod should be no more than $45 from acura dealers if its in stock $75 if its special order.
I think I have a pretty good grasp of what your taking on since I did this exact swap last your in April. I swaped in a JDM 00 (98 spec) ITR engine onto my 91 obd0 chassi and ran into alot of bumps in the process after the swap so feel free to shoot me a email on any concerns or follow up with us in the forum.
side note you should try to get another usdm ecu and chip it to have your vtec set at 5,5k rpms, that is the sweet spot when running a SIR short geared tranny. Im running a jdm Y1 LSD tranny from a jdm CRX/Civic SIR.
Make sure you also get a set of skunk2 magnetic engine & tranny drain plugs for $30 a set, Fuel pressure guage and fuel pressure riser to adjust and make sure your fuel pressure reads 43.5psi. A good fuel pressure guage is made by NRG and those are liquid filled and more accurate than most. If it idles a little high you can always turn down the idle by turnning the screw ontop of the throttle body. My idle is set a little high at 1K rpms after warm-up, a new fuel filter and fuel pump is good later down the road.
Couple things I wanted to bring attention with the post above…
  1. If the JDM ecu won’t crank the motor, neither would the old PR4. And with as much money as Jake spent on this swap, it’d be pretty asinine to not run the right ecu. Something else to think about too Jake, would be to eventually upgrade to Chrome, Neptune, Ectune, etc… With some good tuning on the stock motor, you should be able to get some more out of that sucker
  2. Regardless of the motor mounts he’s using (Hasport, Innovative, Avid), they’re going to put the axles in the stock position. There aren’t any B swap axles being made for the DA, so there’s no reason why stock axles wouldn’t work. Not to mention, the fact he doesn’t need “250hp” axles, as stockers are sufficient enough.
i did this swap in my da =) http://forums.g2ic.com/showthread.php?194601-FINISHED!!!-JDM-B18c-in-93-LS…-PICS!!!-56K-BIG-WARNING!!!&highlight=
da6xsi06 you are wrong about a few things…
  1. why would the jdm ecu not work?.. doesnt make sense…of course it will…
  2. the mounts. it doesnt matter… as mr penny stated all mounts have axles at stock position.
  3. why in the hell would he need 250 hp axles? stock will be more than enough…
listen to mr penny… very few ppl know what their talking about in this forum… he’s one of the few that know what their saying…
I think the point behind the ‘250hp’ axles is simply due to the age of current axles (presumably). If they have the mileage on them that most of our chassis do (150-200k miles), that new ones would be a good idea, and why not something extra ‘beefy’ while he’s at it?
Though I agree, those would be way overkill for a stock GSR and that oem replacements would be fine.
Everything MrPenny said is spot-on though.
  1. JDM ecu will work fine
  2. LS axles will work fine for BOTH LSD and non LSD. You must reuse G2 intermediate shaft if you want to use the LS driver side axle. Otherwise if you have the DC2 intermediate shaft, you must use DC2 driver side axle.
  3. DC2 GSR (or type-r) upper rad hose works the best, no trimming or anything required should just fits right in (assuming stock G2 radiator and p72 head)
    Use the Stock 2nd gen lower rad hose.
  4. Stock shift linkage will work fine.
yeah, I’m reusing the LS intermediate shaft, so I should be in good shape in the axle department, as the axles only have about 6,000 miles on them. fairly new.
I will be using a stock radiator. ordered from a dealer about 8 months ago (old one had a crack near the top), so I have options. nice. I’ll see how the LS upper hose works first, then if I’m not liking the fitment, I’ll order a GS-R upper hose.
A tunable program is on the pipeline, penny :wink: as of right now, I just want the motor to run. considering its a 40hp improvement right out of the box, I believe I’ll be satisfied with its performance for a few months. Hondata S300 will likely be the program of choice, as the closest tuner to me specializes in it. I’ll definitely run a modded ECU when I swap intake manifolds for a more conventional setup (Skunk2, etc.) and get that VTEC engagement point changed. Perhaps next year, I’ll put in some higher compression pistons (might run a SLIGHT amount higher than stock JDM ITR) and a set of mild cams.
should be a fun setup when done.
thanks again, for the help, everyone :up:
Word, since you’re reusing your old half shaft and axles, make sure to get that driver’s side axle seal (the dimensions are in my above post to confirm)
And yea you’ll for sure benefit from upgrading your ecu. Don’t get rid of that old PR4 either! I’d keep it for when you do upgrade, all you’ll have to do is add VTEC (don’t worry about not having a knock circuit, it isn’t worth a damn), install your tuning hardware of choice, then you can have an ecu that mounts back in the stock location!
meh, i’m undecided about the old PR4 ECU. may keep it to have something to modify (that I may not use, more of a “tuned backup”) so in case I run into any issues with the P72 ECU, I’ll have something to fall back on. Or, have an alternate tune for all out power/performance for track days, and keep the P72 setup for a more potent daily driver setup.
you shouldnt need to do that. Hondata has a feature that allows to run a second map that can be used with a switch :wink:
I’m doing this same exact swap right now into my 1992 LS. Can anyone confirm which power steering brackets to use to continue to use the LS power steering pump? I saw a thread on honda-tech where someone said you have to use 94-95 del sol vtec or 99-00 civic si brackets in order for the pump pullies to line up. http://www.honda-tech.com/showthread.php?t=2869241&highlight=b18c+power+steering+bracket I can assume that’s correct information, but before I go out and buy the brackets, some confirmation would be nice. I much prefer not to use washers.
Thanks!
-patrick
Its not a matter or using washers/spacers… the bolt-pattern on vtec head/brackets is different.
I thought any b16 (99 si or del sol vtec) mount would work, but I’ve also read someone saying that it must be a bracket from the B17.
thank goodness I’m not using power steering anymore :up:
x2
No PS/AC is the way to go.
I could live with out power steering, but I can’t live without a/c. My other integra has neither, I’m trying to keep this one more street friendly though.
u need a b17 powersteering bracket or a jdm b16 xsi power steering bracket from a da9
here is my swap let me know if you have any questions
[QUOTE=billys_da_integ;2201995]u need a b17 powersteering bracket or a jdm b16 xsi power steering bracket from a da9
http://forums.g2ic.com/showthread.php?194601-FINISHED!!!-JDM-B18c-in-93-LS…-PICS!!!-56K-BIG-WARNING!!!&highlight=[/QUOTE]
This ^ , or you can use the stock LS bracket and shim it with washers. The adjustment bolt will not line up though, but you can easily adjust tension with a long pry bar
