i was looking at my jdm cluster and it appers to have diffrent warning lights on it, but i HAVE no idea what they mean? does anyone here or know or have a link i could read into to make them work properly?
These are the only two things that’s different. the circle is for e-brake and the other one that looks like a bowl of pho is for your lap belt. The last one is just for the trunk. they’ll work properly all you need to do is plug and play.
I believe that 2nd symbol in the row is something to do with the exhaust system / emissions. It doesn’t have anything to do with the seatbelts. On the USDM cluster, it just happens to be in the same spot.
the second one is for the cat i think
you are correct!! it has to do with the cat, when it s hot it comes on so you wont park over some tall dry grass. thats the purpose for it, i guess theres a lot of tall grass in japan! ![]()
oh foreals, how do you hook that up then? its weird cause once i put on the lap belt it goes away
if you order a DA cat from japan it will actually come with a wire that goes connected to the cluster.
