JDM Cluster questions?
Ive searched and couldnt really come up with an answer. now with the jdm DA cluster do u have to convert to electronic vss??.. ive heard from some ppl that u have to then from others that u dont. and is it just plug and play with wiring? or do i have to switch up some wires? thanks for the input
Hey all JDM DA clusters are plug and play the only thing that’s hard to do is plugging in the cable speed sensor cause there is little to no room to work with
thanks for the info. yea i learned a trick to that, just unplug it from the tranny and pull back on the cluster, not too hard though and it gives ya more room!!
I have a JDM cluster that worked fine in my 90’ Da, but Now that I put it in my 90’ db1, only the tach works. The speedometer, gas, and temp gauge are all dead. The gas light comes on when I need fuel, and the check engine light comes on too… what could be the problem
All Da’s are cable VSS driven
You can use the USDM speedo in place of the JDM one. It’s like 3 screws. When it’s off you can swap the odometer too.
:getsome: :manual:
Corniest quote ever: "Get yours today! JDM is IN!"
