JDM cluster. symbol unknown. What does it mean?
on the USDM. the seat belt symbol is there. But on the JDM Cluster. its something else. looks like heat waves. but car doesn’t over heat at all.
heres pic…
i’m pretty sure thats the catalytic converter overheated/malfunction light, but since you didnt change any pins, i’m guessing its still the seat belt light
can you just install one of those or do you have to redo the wiring and stuff?
there is a heat sensor on the catalytic converter which is pre wired into the jdm wiring loom, you would have to get a diffierent catalyic converter, remove the seats and carpet, run wires from the cat up to the dash clocks, i really dont think it would be worth it…
wow. ok cool. thanks guys. now that i look at it. it does look like the cat-converter.
well. i guess im just going to take the light bulb out of that socket.
thanks guys.
o and 91b18ls , its just a plug and play. no rewiring needed at all.
