jdm engines...
Hi. Not sure if this is the right spot to post but there is a lot of debate stuff here about motor swaps.
My 93 teg broke a rod. Yes you heard right, half of the rod is connected to the crank and the other half is just sitting in the cylinder… convieniently smashing the valves. I am looking into swapping the b18a for a b16a.
Basically, I know what to do for the swap and all of that. Thanks g2ic!
I was looking for feedback on experiences with ordering a jdm one. Any bad sites? Good sites? I have found a few sites that sent me compression info but they could be lying and send a crap motor but tested a good one… I checked the sponsor sites and none imported the engines.
hmotorsonline.com
passwordjdm.com
actually, there are some places that you can request a video of a compression test and they even show you the serial number of the exact motor that you ordered. one of my buddies ordered his motor like this. i did a compression test after we installed his h22 and came up with the exact same results as the video. if they say they don’t have time, chances are they are a bunch of rip-offs.
btw if you get a b16a for your 93, try get an xsi swap, you will get the short geared ys1 with it and 168hp, not too shabby!
mind if i ask why a b16a?
The B16a is a nice little engine I had one in my XSI, you will enjoy the vtec it is a nice change from the b18b. I was thinking about doing a b16 in my turbo GS, The biggest reason the b16 is so popular is because of the price comparing to other vtec motors.
a b16 is a good motor i just took one out and put in my built type R motor. a b16 is as fast as an ls motor give or take. y is this a b16 dont have st for TQ. TQ wins races not HP. now a b16 has a great rod to stroke ratio so u can rev the fk out of them if u change the valve springs. i took mine to 9000 rpms all the time but i had head work done and still runs like new. if u want to save money and less work take a b18 but if u want vtec at a good price get a b16 if u want the best of both worlds do a ls/vtec of a 1.8 vtec motor and spend some $$$$$$$.
…Tell that to an F1 race team.
Torque wins DRAG RACES. Mid-range and top end horsepower win circuit races.
My thoguhts exactly…torque wins drag races…
… and only the east coast still gives a shit about drag racing…
:run:
[QUOTE=kNOwLedGe420;1731434]…Tell that to an F1 race team.
Torque wins DRAG RACES. Mid-range and top end horsepower win circuit races.[/QUOTE]
u ever seen a da on a f1 race team with a 4cyl vtec or ls? im talking drag racing and autocrossing. even on circuit racing u can have all the power u want but if u dont have much tq u are not going to get there fast. fl race teams have great tq.
… and only the east coast still gives a shit about autocrossing…
Try again.
The power a Formula One engine produces is generated by operating at a very high rotational speed, up to 20,000 revolutions per minute (RPM). This contrasts with road car engines of a similar size which operate safely at typically less than 7,000 RPM. However, the torque (turning force at a given speed) of a Formula One engine is not much higher than a conventional petrol engine. For example, the 2006 2.4 litre Toyota RVX-06 V8 engine produces 552 kW (740 bhp, 751 PS) at 19,000 RPM and outputs 274 Nm of torque giving the engine a 14.3 bar mean effective pressure. This is comparable with the 14.3 bar maximum MEP of the 2003 BMW E46 M3 CSL, the best production car in this respect.
Dude, that’s so not true.
Most circuit cars that have low amounts of torque make up for it by increasing their final drive ratio or using shorter low gears.
Torque isn’t going to do much for you on a course where you don’t fall below 50mph.
Far out why do people complain about the lack of torque all the time? if you dont like it go diesel! then you can have all the torque and no power
