i got everything with my new lights:
lights, h4h bulbs, and harness.
real easy instal…just cut and soldered the coresponding wires to the harness and plugged everything in EXCEPT the fog lights, it seems that the plugs were missing.
So i decided to leave them unplugged for now assuming the body shop had stuffed the plug behind the headlight and baffle to where i couldn’t reach it. BUT now when i turn on the light switch to the first position/parking lamps, the fogs come on?
what is going on here? You cant plug the other plugs into other sockets cuz they only fit in one or the other correct?
so i have constant fogs and no corner lights.
you installed them wrong.
http://www.g2ic.com/tegtips/lighting/26.html
http://www.g2ic.com/tegtips/lighting/6.html
that’s how you install them.
