just bout the front end for and i slapt everythin in i even used the oem supports but there seems to be a gap in between the hood and bumper meet is this normal? or wat would i need that im missing ?car is a 93- and front end is 90-91
if everything else is lined up correctly, there shouldn’t be a gap
are u still using the 92-93 mounting blocks? perhaps the 90-91 bumper support beam is damaged.
are you using 90-91 or 92-93 support blocks? they are different. you need to use the years block with the same year support. the skins are interchangeable.
adjust the hood
ive adjusted the hood i am using the 90-91 blocks prety much the entire 90-91 front end and still have a gap maybe my suspension is off and its causing it to be that way cuz ive try the 92-93 hood and still the same thing unless i have to adjust the hood latch thingy ill try to take some pics and post them so that u can see
