JDM headlight wiring question
I was looking at my 1 pce headlights, and I noticed that on the usdm, there are four sets of wires. The headlight, foglight and two on the corner. On the JDM, there are only three. Which of the two corner light connectors do I use. Do I just leave the other one there or cut it off or what??? TIA
if u want it to blink then use the blinking one if not then use the other one. better if u just leave it there and not cut it. u might need it later on, but do what u want.
If you do decide to cut it leave enough wire so if you need it again you can splice it in
Use the blinking one, put a 194 bulb in there, and just let the other, non-blinking one hang somewhere hidden. Easy as that.
thanks for the help guys
I got confused as to what was wrong with my headlights. I have one more question, which one is the one that blinks?? The one closest to the fender or the one closest to the headlight??
Just put your hazards on, run to the front of the car, see which one is blinking with the hazards, mark it, then turn off the harzards.
its the one closest to the fender
Thanks for all the help guys, I’m a dunc when it comes to wires and electronics.
