jdm lighting problem
I put on my 1 pieces about a week ago and the when my normal day lights are on the driver side buld doesnt work but the passenger side does and when the high beams are on the driver side works but the passenger side doesnt. Is this a wiring problem? or do i need new bulbs.
I think you’ve blown a fuse. Check both low/high beam fuses. It’s most likey the problem. Other than that, you may have wired something wrong, if you did any wiring at all. Good Luck and keep us posted.
Re: jdm lighting problem
I finally just rectified this problem…’
My problem wasn’t that it didn’t light up at all tho…?
My highs would be on the left on low beam and highs on the right on high beam,- visa versa –
if this is simlilar…
Turn on the lows, which ever is not lit, or on high beam, swap the wires, from top of the socket to the left I believe.
I guess, it could be anyway tho, depeding on how the lights are wired. It is almost impossible for us to give advice without seeing the car… Good luck.
