jdm mirrors without switch
is there any way i can hook up my jdm folding mirrors so they fold in when the doors lock and unfold when they unlock? i got my mirrors today but they have no switch or relay. so im going to get the radio shack relay and i want to do this without the jdm switch if possible
I have the jdm switch lmk if your interested.
how much shipped to 95355? im trying to do this without the switch. im thinking to have them fold in when i arm the alarm and fold out when i disarm. but if i cant figure it out ill def. keep you in mind
35 shipped lmk thanks.
Get a DEI 530T, wire like power windows, it should work.
GWA will close them and use OEM alarm disarm to open them. 94
how do i do this? i have a gravity g4 2 way paging alarm
The same way you would wire it to power windows, the 530T comes with instructions.
Keep in mind I said " it should work".
Getting the 530T to fold the mirrors is not a problem, the mirrors work the same way as power windows and power door locks, reversing polarity, supply power to one lead of the motor and ground to the other and motor will turn in one direction, reverse the wiring and motor turns in the other direction.
Controlling the 530T is also not an issue, your alarm will have the outputs to trigger the 530T.
The issue will be, [if it is an issue at all, and I do not think so] will there be enough resistance once mirror is all the way in or out to turn off the 530T, the 530Ts “stop resistance” is adjustable…
http://www.directed.com/guides/manuals/ig/accessories/N530T_1-00.pdf
You would not need the switch side of the wiring. 94
fcm
i have a question i have the switch an relay for it an mine are working like the should i have a g5 alarm could i just add another relay to make it work?
Just adding a relay will not fold them in and out when arming/disarming alarm. 94
ok thanks i got another question if you could email me at greazemunkey73@yahoo.com about door locks an e brake?
Sorry, I don’t do email, ask your question here. 94
how long do the mirrors motors usually last?
ok well i am not sure how to start a thread so i have a clifford g5 alarm with door lock that work but i also want to hook them up to my e brake (pull it up they unlock let it down they lock was told it only a couple relays how do i do this ? (had it before on a nother integra)
All you would need is a SPDT momentary switch, mounted so when setting or releasing the hand brake would “flick” the switch, ground into the switch and the outputs to the same place the alarms door lock outputs are connected.
However, as the hand brake is set when not driving the car and released when driving why not just program the alarm to ign. controlled door locks, they would lock when you start the car and unlock when you turn the ign. off. 94
yes my car is like that with the ingition but i like how i pull up to a friend pull the ebrake an the door ulocks then let it down an it locks that way it works both ways thank you for the way to do it
