Jdm one peice problem
ok i looked around a lil bit and still could not find out whats going on
heres the deal my fog lights on my one peices work but one is dimmer then the other fog light i was wondering what may cause this ???
I had this problem at one point in my old set of 1 pieces, The fog light yellow comdom in 1 light could be rusted out or broken.
A bulb could be of a different wattage or you could have a bad ground somewhere… I never fixed the problem with the old set and just got a new set instead. But thats what i was told is the problem.
its def not that the yellow condom is not broken or anything ware can i get wiring diagram for the lights so i can find out what i need to do any other help would be appreciated
did you try swapping the bulbs from the left headlight to the right and vice versa?
i had that same problem at one point… turned out the wires weren’t “done correctly”
i have the same problem but the yellow cover is rusted.i took the bulb out and the metal thing had rust.i need to open the headlight to change it
