Hey G2ic, I have One pieces on my DA and for some reason the driver side headlight does not fit as well as the passenger side, does anyone have this issue? The area by the foglight on the driver side sticks out a bit in front of the hood… maybe by a few centimeters… I’ll have pictures up later today so things can be a bit more clear, but if anyone has a solution, I’d greatly appreciate it, thanks.
Did you completely take your bumper off? Check the geometries of the other headlight and compare them to the one that is being a pain. The brackets might of been bent in shipping. Pictures would def help.
No problems at all for me. It’s probably your car. The frame has prob been in a wreck.
unbolt the screws on ur bumper an move it around again the bolt it back on but before you do so check if the headlights line up this time, Thats what i did and it fixed my problem
Sorry I’m way late on this but here’s some pictures. And its never been in a wreck, clean title and all. Never been fender bendered or anything. Everything else seems to line up except that one section. I think it may be that when my uncle zip tied my bumper instead of bolting it under the car… the driver side is pulling back farther than the passenger side, therefore causing the driver side to look uneven in that one area.
Pictures below --------------
Drivers side pictures :
Passenger Side :
And if i can remember… doesnt the foglight portion of the headlight, go maybe a few mm behind the middle of the hood?
passenger side needs to kick out some…driver side is fine
Best bet is the car being in a minor hit?
X2 on minor hit. Could be anything. Take off the bumper. Try and do some aligning on em. Even if you have to add washers or something…
Passenger side looks like you are missing the lining that goes under the headlight. It connects to the bumper.
Passenger side of the bumper just sags a little bit because theres only 1 screw holding it in on the bumper support instead of 2. I’ll just mess with it a bit and see how it goes.
