JDM one piece fogs problem
wassup yall im new to this site. well, i bought a set of one pieces for my teggy and i installed them the other day. however, i didnt install the fogs because i was missing my jdm fog plugs that have the lil bit of wire sticking out of them and plugs into the fog socket on the JDM housing. yeah, my one pieces never came with them so i couldnt wire them into my USDM fog harness. Now, where could i find some spare jdm fog plugs OR how can i solve this problem.
PS. I dont wanna use my other sidemarker harness b/c i want to be able to turn the fogs on/off with my fog switch. please, any help would be appreciated.
okay let me put it in other words: how can I wire up my fogs without my jdm fog plugs… maybe i could use some spade connectors and attach em to my usdm fog harness… then just plug it into the jdm fog socket? although i do not have experience dealin with connectors and all that stuff…how would I go about it if I go that route… it looks like spade connectors could plug right in
when i did mine i pulled out the stock connectors off my usdm lights so that i had about 5 inches of wire left on it then used the connectors off of my old turn signals from the corner markers, pulled off the back part that angles the wires down. just splice the old signal connectors to the usdm fog connectors, obviously red to red black to black. the use them as an adaptor if you will so that you can use your stock fog connectors with the jdm lights
if ur referring to the usdm corner lights that blink, i used those for my jdm corners… the ones i didnt use were the ones that stay solid… and the solid/blinker harneses are both different i dont think the solid ones can plug into the jdm fog socket
get some side markers, then reuse the connectors
