so on the usdm lights, on the corner marker there is 2 lights, one always stays on as the running light and the other one blinks when you put on your turn signal. on the jdm lights, is there only 1 corner light instead of 2 like on the usdm ones??
That is correct. It is done that way because JDM cars have sidemarkers that take the place of the second bulb.
oooooohhh
Yep and out of the 2, the 1 that does not blink is the only 1 that fits in the 1-pieces. If you wanted it to blink you could swap the connectors.
