JDM Side Maker
I just recently installed my JDM side markers and I currently wired to the turn signal! So here is the question do I keep it the way it is or wire it to the parking light? Any suggestions will help
Side markers are extra turn signals. Theyre not meant to be parking lights.
Your car, do as you wish.
[QUOTE=DA_all_day;2315770]Side markers are extra turn signals. Theyre not meant to be parking lights.
Your car, do as you wish.[/QUOTE]
Yes, it is my car but I am doing mods the right way with no cutting of corners. Thanks for your input!
It’s not about right or wrong…
The JDM sidemarker is used as a blinker because the JDM one piece headlights don’t have blinkers in them.
The USDM headlights have running lights and blinkers all in one.
Depending on your setup, you can make them do whatever you want. They’re simply different accommodations for different setups.
Found out that my side markers are plug into the turn signal harness and it has both parking and turn signal so I am all set!
