JDM window visor tape size?
Well im about to install my JDM visors and was wondering if anyone anyone kno what size the double sided tape is that holds the visors in place?
Thanxx guys.
I got 3m tape from walmart an i just trimmed it down they only had one size there
can u post some pix ?
i tried that but didnt like how it came out.
Go to your local body shop and ask for the below tape, you can get a small roll. It will work better then this 3M stuff From Wal-Mart> http://multimedia.mmm.com/mws/mediawebserver.dyn?iiiiii6pAuxiC4JiW4Jiiil9dUeIIIIg-
http://multimedia.mmm.com/mws/mediawebserver.dyn?222222PNZ6729Jg2tJg222gUqrB02rOy-
the tape he said to get is 3m tape same stuff at walmart
Both good tapes… Just making the point the 3M tape from Wal-Mart is good for lighter duty badge mounting. I used the lighter stuff till, I found out about heavy duty stuff. I found that the heavy duty 3M tape, works better for visors and things like that, will not come off in the wind, and has better water protection then the lighter duty tape… Just saying
Yes, just to add to this, 3M makes more than one type of double-sided tape. the industrial heavy-duty tape is what others are using for side skirts, rear visor and things such as the JDP trunk spoiler. It’s a must that if you use 3M tape on the exterior, to use the heavy-duty. we don’t need body parts flying off your car.
