Hey, i dont think this is a tranny problem but it has only happened in fourth
I am accelerating or pretty much just got into 4th and it jerks foward a little bit when i am driving, like when you’re walking and someone gives you a little push from behind. It lasts a few seconds and stops, but it has happened twice and i would like to nip it in the bud before it becomes a problem. My distributor is relatively new so i didnt think itd be that, like its shiny and sticks out in the engine bay as a new piece. Anyone come across this before?
clutch is pretty old, i drove a subaru legacy and it was SO easy compared to mine, i could prob use a new one deff but i didnt think that would cause it. It ranges from 30-50 miles an hour, i dont wanna say it is only in fourth but the past couple times thats what gear i was in, and this is when im accelerating. I dont know the exact RPMS but it would be between 2-3 cuz i shift when it reaches 3
it happened again, this morning in 4th, my RPMS were 2500 and i was going around 40mph. It was while i was accelerating (speed limit was 55), by the time i got into 5th it was gone
ok, i put it in 5th and let it drop down to 1200. I gave it a lot of gas. I heard a rapid rattle noise coming from my glove box area. The two needles mirrored each other in position and speed. It was like they were measuring the same thing it was a little weird.
pull them out, inspect the o-rings, pull the injectors apart and check for any abnormal wear or clogging… clean them up and go for a rip and see what happens…
