Just did my 4x114 conversion and slapped on my new set of wheels.
how do you slap on that stufff?!
like I said no one needs your 2 cents. plus stick to your 5 lug with them OEM wheels of yours.
sorry i didnt mean for your thread to turn into this i was just curious how you did yours and if you have had any problems…
5 lug knuckles are different from 96’s. the 96 4 lug are almost identical to a DA’s. only slightly taller. whereas the 5 lug have a dramatic difference in the curvature.
there. you’ve been enlightened. :hi5:
all you need is a front camber kit that allows negative adjustment. just beware, if you slam it hard, you will bottom out on your strut towers. but that goes without saying anyways
or maybe it’s just because i’m using skunk2 A arms
i’m riding about as low as da408 in the front. but any lower than that, and you’ll start hammering your towers
LMAO OEM wheels keep thinking that buddy, lets see i have two cars a daily and my DA and my daily has wheels that cost more than you car+mods and wheels combined.
Now I remember why I stay away from these forums.
OMG two cars??? And one of them is worth more than his 20 year old Integra???
NO
FUCKING
WAY?!?!?!
Get over yourself. If you’re going to give input and clarification to back up why you feel the need to be such a douche, then do so. Otherwise kindly stfu.
Apparently you dont. Now, let me remind you why you should…The information you so rudely threw out there was dead wrong, so you were no help there, AND you’re a pompus E-thug. sell your teg. ditch our forum.
its ok im buying the koni/gc with extended top hats comes with revo technica upper control arms…ive also seen people cutting out the strut towers and welding in exteneded area to for the uca’s to move more but im not going that crazy i still want to heep my header intact
yea you should be fine then. you’ve got 16’s and a header, so i would’nt presume you’d be going all that low. but remember, the lower you go, the less negative adjustment you’ll need. how much negative adjustment do the revo offer? if it’s up to 3 degrees, you should be fine.
you won’t need to modify your towers. if you did, i would have just said machine the DA hubs instead;)
awsome i will check into that when my suspension comes in
how did you make it 4x114
