interested in k swapping my teg, anyone have any pics of oil pan clearance? i plan to use hasport mounts and k24, hows the suja 1 hydro kit? are people using a regular “k swap” header or does it have to be da specific? thanks for any advice
I believe that they oil pan for the k24 is bigger then the k20. You can use a k20 oil pan if you change out the oil pump in the k24, People are using the s2000 oil pump for the this.
I would thing a k swap header should be fine, I know they make them for the gen 2 integra, probably gonna need a different traction bar.
i know a lot about the k motor, and k swap itself in more popular chassis, i have a eg hatch with a k24…just dont see a lot of info for da’s with k…curious how people are doing with oil pan clearance…ill get rid of the front subframe with the full race traction bar, thanks
http://forums.g2ic.com/showthread.php?201419-K20-DA-s-Anybody-built-one
could look in that thread to ask questions and see what others have done…
thanks…not too much info in there tho
There is a member on hondatech doing this build as well and has a lot of info with pics in his thread.
alright cool im gonna look for it thanks
so basically just have 2 important questions…1. hows oil pan clearance with a k20 and hasport mounts, since i assume k24’s extra 19mm is gonna be a big difference with this swap…2. what cooling setup are you using? (rad, hoses). thanks
K24 are only taller from the top…the block and oil pan sit at the same height.so if your doing a k24/20 you might need to trim the hood or even cut it like how you see them EF civic and crx are. but im not sure yet because ive never seen a k24 da integra yet…o and the k24 oil pan is made out of steel and the k20 oil pan is made out of aluminum
