[QUOTE=kyle10182;2260092]been there, done that.
http://forums.g2ic.com/showthread.php?153300-i-hate-innovative&highlight=hate+innovative
back in '06.[/QUOTE]
Good link, even shows the rear mount bushing sliding out like how mine where doing.
like i said, im in the process, and not 100% sure when ill be done, im just taking my time and dont want to rush it
what all fab work do you have to do for the hasport mount kit sorry if this has already been covered also what do you have to do to hook up your stock speedo cable or can you and last question if you get the most complete kit that k-tuned makes what does it lack to complete the swap?
im not sure about the hasport mounts, im pretty sure they make a kit anyways and you have to change the passenger side frame rail mounts. the stock speedo cable can work depending on what year transmission you get. i forget what years are compatible but you can use a crx speedo gear in the back of the tranny above where the half shaft goes in. if not you gotta go another route. It would be mainly wiring, they dont have any kits compatible with the car. other than that just little things like the speedo, rad hoses, gas line kits etc
how do you manage to operate the k Trans clutch with our cable chassis. and the speed sensors
what traction bar are you guys running to bolt the tranny to for extra support.
the k tuned bar is for a stock b series.
