hello as the title states, the turn signal switch that you use to turn on the headlights is not working for me. ( the knob you twist to turn on the headlights basically) . It worked fine when i turned it slow back then, but last night i was in ahurry so i just twisted the knob really fast to turn my lights on, but it wouldnt turn on. and since then, it hasnt worked. i checked to see if it was fuses , but it wasnt. besides getting a new turn signal assembly, is there anyone here who can think of a solution? thanks
u could try repairing the connections (soldering). or u could just find someone that is parting out their ride and buy it used. junkyard… or u can be a bit ghetto and hook it up by toggle switch.
so easy to just find one and replace it…
generally…
remove center of steering wheel cap
mark UP with an arrow, or notch or something… nice good new sharpee marker, draw a equal mark " = " upwards, makes it more clear to find exact point.
pull steering wheel off
unscrew 2 or 3 screws holding the column cover on
pull covers off
unscrew
unclip
remove
clip in
install
screw in
etc…
badabing badaboom
(misc. steps might be missed, etc etc do at your own risk, blah blah blah)
unplug the harness that plugs into it,
