Knock Sensor again...
I am a newbie…From the codes I pulled i got code 23 the knock sensor…How do i know if it is the sensor that is broken or if it is the engine???because someone told me that even though u dont hear the knock u can still have knock…
What setup are you running and what gas are you running in it?
Have you tried resetting your ECU yet?? That would be the way to go for the meantime. Clear the code then see if it comes up again. If it does, then you have a problem.
Later,
BR
no i haven’t tried resetting the code yet…is it true that i can still have knock if i dont hear it???
o yea… i have i/h/e
Yes
Later,
BR
