I can’t figure out what it is but when i turn left or right i hear a knocking noise. I don’t know what it is. someone help me thanks!
sounds like a Axle problem… check to see if your cv boots are rip open…
Axles would be a clicking noise. Knocking could be motor mounts, suspension lose, wheel not as tight as it should be, Just make a list and start checking for anything that may look suspicious.
Jack the front end up and make sure the steering wheel isnt locked and shake down the front end. Check you tie rods and check your ball joints or if you dont know how to you could take it to a shop and have them do a front end check. I will try to find instructions to check the front end.Here is two Links that can give you an idea http://www.youtube.com/watch?v=GDAFxt46PHk&NR=1 and http://www.youtube.com/watch?v=HKk33w86OSI these are just some general ideas.
I would suspect bad inner tie rods, or ball joints.
Check your wheels for any play in them
clicking while turning is your CV joint…your gunna have to change the axle…and your boot doesnt have to be ripped for it to start clicking …what happens is that one of the balls fell out of the cage …so while your turning the ball is scraping against the cage bcz its spinning…very easy job axles are about 30 to 40$ and its like a 10 15min jobb
