Koni Height Adjust
I was wondering if the Koni yellows height can be adjusted up and down? Well I do know that they can drop your car a bit more, but i was wondering if they can also lift it, if in case your springs happen to drop your car too low.
The perch can be adjusted a teeny bit up or down, roughly 1/4" up or down. There are 3 grooves on the shock body, with the middle groove being stock height, and the upper raising the car, and the lower lowering it. If you want more adjustability you’ll have to go with coilovers.
