Tokico blues can’t, Tokico Illuminas can. I’d say go w/ the GR2…but there won’t be a warranty that applies to you. It is voided after more than 1.5" (they can tell if you went lower by the shock rod). Also, if you’re buying them used…sometimes the warranty is non-transferable, I know Tokico is like that, not sure about KYB.
I have the Neuspeed SofSports, and even with an empty tank of gas, my left rear wheel gap is smaller than any other wheel. It’s not too bad, about 1/3 of an inch difference. Unfortunatly I didn’t measure before I did the drop, so I don’t know if it was like that stock.
im getting skunkworks coilovers. I have no clue how much i will drop it yet. ill figure it out when i install them. I also have the ingalls camber kit (3 degrees). Do you guys think ill have any problems?
