Innovate motor mounts, new in the box 92-93 MT Integra $200
OEM P30 ECU $100
Chipped P72 with two step, factory GSR tune $125
Gauge clusters Non VTEC $50 VTEC $100
DA/DB Spoon mirrors painted AGP $75
DC 4-1 header, Type R rep, never mounted, had some surface rust from sitting in my garage, had them sand blasted and recoated $100
AGP DB2 wing, needs new mounting studs $50
VTEC valve cover that I had sand blasted painted and hydro dipped. $150
Wildwood Brake Booster delete for a DA/DB never used with adapter $150
OEM Stanley one piece lights, need cleaned and has a small Crack in one corner $150
B17 block, crank and parts. No oil pan or timing cover $300
B18 non vtec block crank and parts $100
XTD 10 lb flywheel clutch and pressure plate, with pilot and throw out bearing $175
I also have OEM flat sides for a DA/DB2 chassis $300 and I’ll take them out of the box and send pics if your serious about buying.
Some of the prices I’m negotiable others I may tell you to kick rocks, don’t be offended, I just spent a lot of time and money collecting parts and I paid more for it than what I have listed
602-689-1916 you can text me as long as the hour of the day is reasonable. I’ll try to get back to you ASAP
