lca + shock question
i have 91 integra 4 door
but anyways,
i have a pair of rear koni yellow’s for 97-01
i also have the itr lca’s
technically it should bolt up properly correct?
any extra parts needed? just want to make sure before i take everything off to bolt it up
don’t want to do it half way then find out its no good! >_<
thanks in advance
p.s i didn’t purchase the fronts yet but would the 97-01 koni yellow’s fit on without the front lca? or do i must have the itr front lca’s too
yes i know its a werid question
=o)
If your rear shocks are not for an ITR and you have ITR rear arms they will not fit. The ITR rear arms are the box in type (yours are, arent they?) (box type - shocks are “boxed” in by the LCA’s) and the DC non ITR shocks slip over solid control arms (90-01 teg). Sooooo, you are going to have to get some non ITR arms.
But if your shocks were for an ITR then you can ignore the last paragraph and put the shocks in without trouble.
You dont need DC front LCA’s. The front shocks will fit with DC/EG forks. The only difference in the forks is that the hole where the shocks fit in is bigger on the EG/DC pieces. If you want I have a pic of both the forks side by side, but I dont want to dig for it right now.
HTH
Ben
I’ll buy your rear lca’s off you… Please???
Schu
thanks ben for the reply
i was trying to understand your post awhile ago about the hybrid suspension
the shocks are for 88 crx/civic or 97-01 itr
so i’ll be looking for either of those lcas
they are rears only
now if i run those in the rear, should i be using gc coilovers for a 97-01 itr or should i be using gc’s made for da?
The coilovers dont matter. the only difference in the shock is the LCA mounting point. The spring perch (or I should say snap ring for your konis) is the same. Just remember to get koni yellow specific GCs.
The 88 EF LCA’s are 1/16" shorter than the ITR LCA’s. So ITR LCA’s would be better on your integra.
Ben
orrrrr. if u can find em… the JDM DA LCA which are 88 civic/ITR style. just in the right dimensions =)
