Leakin a little bit of coolant but from where???
Well…When I park overnite I leak a bit of coolant on the driver side…
I say its roughly under the alternator and powersteering…
The only possible place I can speculate the leak is coming from would be the overflow resevoir…
Can anyone shed some light on this for me???
TIA…
:slight_smile:
Either you have a crack in the res which is easy enough to check or your water pump is leaking.
also you can take out the plastic cover at the bottom and inspect the bottom of the radiator
SE-37K: I replaced my Tbelt and W/P at 190k kms…I have 241k kms now…So I THINK im ok…I juss recently did my cam seals and there is no sign on coolant contamination on the Tbelt…
jaylo: I juss replaced my rad 2 weeks ago with a new one…
Guess ill check it again tomorrow morning…
Thanx peeps
:wink:
You need a new water pump. When the internal seal goes coolant drips out of the weep hole in the waterpump housing.
The weep hole is right behind the alternater. The same thing happened to me. It won’t contamanate the timming belt because the weep hole is outside of the timing belt cover. If you need me to email you a picture of what I’m talking about email me at
work: jeffcoll@ages.com or home: secondjenn@aol.com
Ahhhh man!!!:shock:
I hope to God its juss my resevoir…
But my W/P is only 1 year old… :frowning:
U have mail 2ndjenn…
sigh
Was it an OEM Honda WP or was it aftermarket??
It was a Honda OEM W/P
I work at Honda so yeah :wink:
Thanx a lot for ALL the replies guys :slight_smile:
you have mail. I attached a photo of where the weep hole is on the waterpump housing. It is just behind the alternater. Time to get the employee discount on a new waterpump.
