I have an coolant leak which seams to be coming out of the bottom of both sides of my timing belt cover, its fairly bad and was wondering if there was anything else that it could be than a water pump failure (Broken gasket). Thx
should i take off the valve cover to check the timing belt for coolant?
PS its a 91 gs
yeah, i’d probably pull the covers off and have a gander in there. if you see a significant amount of coolant, it’s pretty safe to assume. it can’t really get in there any other way
It could be from the O Ring gaskets on the coolant tube that runs along the backside of the block. But if it is leaking as much as you stated then my guess would be that your water pump has failed.
I am gonna say its the water pump and seal. Mine did the same thing about 4 years ago. Started as a small drip but then went to a full on leak and I couldn’t drive 5 miles without losing all my fluid.
