My roof is leaking… i am not sure from where… but i think that it might be the sunroof… the water leaks on the inside of the car from the seat belt track area at the top near the passenger visor and also leaks down by the kick panel of the dash on the passengers side…
check your sunroof’s leak hoses. the driver’s side one is probably disconnected, and the passenger side one is maybe cut, but the passenger side leak may be your cowl inlet for your air to come in the car, that happens to a lot of people.
solution…
if you’re leaking from the top, you probably have the same problem i have. search for my thread…there’s a really detailed explanation and i think your problem was my solution #6.
