the focker leaks when it’s warm. after it gets a chance to cool off, it’s fine…is there some sort of overflow hole that lets extra oil escape? i mean it’s pretty bad, 3 drops every 2 seconds or so…
just changed the oil a few days ago, and changed the washers on both the check/filler bolt AND the drain bolt (like Mr. Helms manual says to do)…GRRRR!!!
as per MrFatBooty’s suggestion via AIM i will be draining out the honda MTF and adding a good hearty amount of valvoline maxlife and seeing if that helps with seals. grr.
umm…yeah so the maxlife isn’t working very well…the leak has slowed but not very noticeably. i’ll be dropping my tranny over winter break and replacing my seals…stupid japanese cars…hehehe:D:D:D
