I just swap out all my tail back up and turn signal lights with led bulbs.
As soon as I put them in I had trouble trying to turn off my lights.
Yesterday on my way to work my clock started to dim when I hit the brakes.
Today I was driven home all my dash lights started to flash, My radio went out, The fuse to my power window blows
I put the stock lights back in and everything is back to normal.
as i was looking at the led bulbs I notice one bulb made a noise. solder on the inside had came loose. that mite be the problem but iam not putting them back in.
LED suck
What’s the advantage of LED lights, anyway? I know they use a fraction of the power of the old-fashioned incandescent bulbs (and thus your alternator doesn’t have to work as hard, putting less drag on the engine), but what does that translate to in terms of energy savings? 0.00001 mpg?
installed properly from the factory they can last a very very long time. you need to wire in resistors to keep from burning out the bulbs. can’t just wire them directly.
though many LED bulbs are directional and do not offer very good lighting at all really… and are relatively expensive.
