lol what other colour would headlights be?
purple and blue, like HIDs
scott (teglovinvtec) has bright yellow H4Hs in his 1pcs
Would blue head lights and blue fogs look stupid?
yes IMO
Yeah, I think so too.
Aight just blue fogs it is. Any recommended store/site to buy from?
did you look at imcnblu’s?
naw. get yellow fogs. better visibility and its t34 JdMness!
Actually yellow light is less reflective than white. I’ve compared before…when steam rises off the road, use just your fogs, then just your lights. The yellow cuts through so much better.
I had yellow fogs in my old pontiac, they were worthless. they provided no contrast. Plus, the color is ugly.
Not if you have PIAAs
i have the piaas in my one peice headlights are they are brightat certain times its hard to explain but looks good tho.
lol, i just told them that scott^
sorry it took em so long to post mine. pretty even color and nice and bright. pic doesnt really do it justice. these are pre led pics. i still am too lazy to take the new ones. plus gf has the camera.
http://i71.photobucket.com/albums/i124/icemangsr/matts%20pics/Picture010.jpg
if you want better LED’s then go to LEDSgalore.com
its my bros sight and he has alot better LED’s than you can buy at any normal automotive store. I have his lights in my tail lights. Dont use them for blinkers unless you have an adapter to add resistance to slow the blinking…can be got at oznium.com!
Bacardi maybe you should READ their website before you order LEDs.
IT CLEARLY SAYS on their website, that the bulbs CAN cause your blinkers to flicker fast. The LED’s dont’ draw as much power, which will in turn make it think it’s got a burnt out bulb (how it tells in the first place). This shouldn’t be a problem in the older cars.
NOT only this, but it even says to NOT use these in headlamps or taillights, as it VOIDS the warranty on the bulbs.
Lastly, it even says directly on the website, that “generally” brightness is NOT an advantage of LED bulbs. They usually have better colors and last longer, but that they’re not usually brighter than a typical incandesent bulb.
If you wanted to use them in tails you should order the special LED’s they use in dumptruck / semi taillights.
Regardless, they gave me a refund :shrug:
