Left Outer Tie Rod!!
I went to the mechanic last night to get my saftey done, and all I need to pass is my tie rod. I’m going to buy the part form acura but am not 100% on how to install it. Does anyone know a link to where I can find out? or if possible give me a detailed description on how to remove and put in the new one. Any help appreciated. TIA
Try this site. It has worked well for me in the past. You’ll have to load your car into their system. No worries it’s free. After you register, just go to “Repair Info”, “Products and How To’s”, “T”, “Tie Rod End”.
Any time you mess with your steering though you should get a front end alignment.
Also, if your going to be doing any mechanical work yourself, get a Haynes Manual. It is the staple for all us Do-It-Yourselfers. Any autoparts store will cary them. Or you can order one from Autozone.com.
Good Luck!:burnout:
http://www.autozone.com
