iv got it raised as high as posible with my own custom extension to make it sit even higher i can make it touch the ground easy but it handles like a arial atom setup like this[/QUOTE]
Uhm… 1. have you driven an Ariel Atom? 2. Wrong thread.
[QUOTE=90-JDM-integra;1921527]kyb Gr2
tokico blues
epic beyond all that has ever been described as epic.
Read through this WHOLE thread and the only question I have is as follows, NSX calipers, are they smaller the the Legend ones? Everyone is saying the Legend calipers are best, why?
your driving at 30-50 mph, and you start to press the brakes… and there it is, squeaks for about 5 full rotation… once the force on the brake pads is greater it shuts up… however, if your in traffic you press the brake softer the noise just stay until you hit the brake again… most of the time its from the right, very few times on the left
i already changed the rh knuckle w/different bearing… nothing changed
Here’s the thing about asking for help from people who don’t follow you around like a shadow 24/7: If you don’t provide all of the information right off the bat, you don’t have the right to act like a question asked is a dumb one.
Since you don’t see fit to share all of the information, and then decide to act like a dick when someone genuinely tries to help by starting at the easiest step, by all means, best of luck figuring it out.
Maybe it would be a good idea to think up everything else you’ve already checked so you don’t waste everyone’s time.
