If you’re like me and got super excited because you found an Acura Legend in your local scrapyard and grabbed the foglight capsules only to come home to find you got them from the wrong generation. They look a little different but can be made to work just as well. Beforehand you may want to remove the glare guard from your foglights using what ever method you prefer (I did so I can’t say whether or not these capsules will fit with the glare guards in). Now for some pictures:
The capsules when you first get them:
With a quick 2 cuts of the supports with a dremel and cut off wheel they come out looking like this:
Then bend the tabs flat with a set of pliers and a steady hand and put them in the housing. Unfortunately you will only be able to get 1 hole to align but it seems to be held pretty solid:
It gives a nice yellow light off with a surprisingly good cut off for no real restrictions in the housing:
