lets go swimming!
ok so i have a pool in my trunk area, i have no clue where its leaking from, do the seals go bad? cause mine looks perfect, is this common on the da? any hints where itd be leaking from?
If you have a sun roof if so check the drain tubes
well first off you might want to change your title before they delete your thread. And to answer your question yeah the seals around your tail lights do go bad with due with time so you might want to check those out and replace them if bad. But im sure that others will have info for you I hope i helped ya out :clap:
I haven’t heard of that problem. Correct me if I’m wrong but isn’t there drains in the trunk area? Maybe there clogged. I’ll have to see for myself. Easy way to find out though. Have someone lay in th trunk and use a hose or a pressure washer and rinse the trunk area down and your sure to find the leak.
check the tubes behind the plastic panels in the trunk and the taillight seals also
