I’m looking for ideas of where to mount aux gauges, I’ve got a triple pillar pod but still need to mount 2 more gauges (boost, oil pressure, EGTs, Wide Band O2 and volts). Might add a 3rd (oil temp).
Let’s see where you’ve got them gauges!
you should search around a bit. there are a few posts that deal with that subject.
yea, but that’s no fun.
EXACTLY! Cuz it ain’t no fun reading this thread :stare::bang:
:umno:
I searched last night, still didn’t find much.
Those running gauge in place for your middle dash vents, did you notice a loss of heat/ac?
:sucks:
:iagree:
:werd: … but u should stop being lazy and search because not all of them are like that and there are a bunch of threads like… 1 and 2
I just got my last gauge…
[QUOTE=Ominous G2;1910712]I just got my last gauge…
how do you listen to music?
I dont listen to it much, plus I have a remote. That panel took minimal modification to the trim, just some small notches at the top. So it can easily go back to stock, but probably never will.
That’s pretty sweet man.
That’s the stuff I want to see.
Thanks, plus when the turbo is done… fuck a radio. My wideband will be the PLX M300 mounted on top of the steering column.
werd. i have no radio in my turbo/stripped out car. you wont hear it and you wont want to hear it when your listening to the car.
i have a dual pillar gauge for my boost and oil pressure. i made a custom plate in the left side vent for my wideband gauge. i eventually want to get a oil temp and water temp. ill make a plate to fit in the radio area for those two.
Ominous G2 - I’m lovin’ the way you mount your gauges… very simple but at the same time… slick lookin’. Shit looks like it means business! :rockon:
Very nice setup and clean…
are the gauges hard to read while your driving?
I want to get oil pressure, oil temperature, coolant temperature, voltage, and transmission temperature. It’s going to be fun trying to place all these.
Lookin good Ominous!
I’ve decided to use an A pillar to house my oil pressure, egt and wideband.
The boost gauge will be in a custom steering column pod.
