I was getting rid of the gay body kit and returning my 93 ls back to the jdm look. I put the back bumper on and plugged up the license plate lights. Well then my radio doesn’t work my clock blinks and the door light on the cluster flashes and i do not have the door sensors anymore. Anyone tell me what i should do or where to start looking to fix this problem thank you if worse comes to worse just unplug the lights
thanks
Start by checking the fuses…
Fuse 14 - 15A, [hot at all times] radio constant power.
Fuse 22 - 10A, [hot in acc. and run] radio switched power.
Both are in under dash fuse box.
If you do not have the door pin switches, make sure the pin switch leads are not touching ground.
Is your 93LS an automatic or a 5 speed?
Title was "License plate lights
" but you did not say if they worked or not once you plugged them in???
Back up light fuse is fuse 1 - 10A on the 93, [hot in run and start] in under dash fuse box. it is also the signal lights fuse, do they work?94
yes they worked just like shorted out some stuff clock blinks when lights are on and radio doesnt work period. But i will check the fuses today thanks for the help
