Links to repetitive questions
as much as we all tell everyone to search, a lot of the good threads that explain a lot of info that has been brought up over and over again has been lost over time. I’ve completely gonse through the hybrid section along with teg tips and there isnt as many good threads clearly explaining some of these issues that I thought. Here’s links to the threads I found that seem to be in question now and then. If anyone else wants to take the time to give their description of something they see on the boards a lot please do so. Also if you know of any good links to threads that are relative to this please link them :up: . And if you wanna bring up a subject that you think should be better explained then fire away :gun: .
resleeving, shotpeening rods, some good b17a info:
http://www.g2ic.com/forums/showthread.php?s=&threadid=18749
http://www.g2ic.com/forums/showthread.php?s=&threadid=10872
function of PCV valve and catch can
http://www.g2ic.com/forums/showthread.php?s=&threadid=16062
ls/vtec, rod/stroke ratios, and other hybrid motor setups
http://www.g2ic.com/forums/showthread.php?s=&threadid=34831
explanation on vtec, cams & cam gears, and other valvetrain talk
http://www.g2ic.com/forums/showthread.php?s=&threadid=9081
http://www.g2ic.com/forums/showthread.php?s=&threadid=8418
resleeving and block guards comparison
http://www.g2ic.com/forums/showthread.php?s=&threadid=4355
discussion on diff in b20 block vs. b18
http://www.g2ic.com/forums/showthread.php?s=&threadid=38257
http://www.g2ic.com/forums/showthread.php?s=&threadid=32132
also under teg tips, there are explanations of ls/vtec install, other b series install guides, b series engine specs, cam installs, and many other things that occasionally are asked.
:bow:
