How do I remove the tail lights? All I see are the little 1/8 inch bolts, from which I’ve removed the nuts - but the lights don’t come off. I can’t see where else they’re connected and I have no manual. I’d be most grateful :bowdown: if someone could explain this. Thanks.
first you take the six nuts on each side off and then give the taillights (on the back side) a good love tap assuming that you have taken off the panel that covers the taillights. if youhaven’t then pull back the carpet and there is 3 phillips screws located on the floor and one phillips screw on each side of that panel under those covers. unplug tails and your home free!!:burnout:
