I got lots of problems and I would rather consolidate them into one post… Since most of it is transmission/engine related I thought this would be the best forum for it.
•Problem 1
When I go to shift into 2nd gear, sometimes it won’t shift at all, somtimes it grinds into gear (even with the clutch fully disengaged), and sometimes it actually goes in but I have to do it as if I wasn’t using the clutch. Any thoughts?
•Problem 2
When I start my car the enigne idle is at about 2k RPM, after about 5 mins or so it will drop to about 750-1200 RPM, but at the time it’s warmed up the engine is producing a completely different tone, and is also vibrating like a bastard. Any Thoughts?
•Problem 3
My wheels feel like the lug nuts are loose on the wheels, but there not. There sorta make a knock noise when I hit even the smallest bump, kinda like the wheel is going to fall off. Any Thoughts?
•Problem 4
When I go into reverse, it makes the most terrible sound, very loud and nasty winding sound. I do have a bad clutch and thats what I think the problem is for this one. Any Thoughts?
Thanks for your time guys, like I said any help is apreciated ![]()
