hey everyone.
earlier this month i went to the adirondacks. en route a big rock dislodged my exhaust and i have a leak. ok, no big deal.
a few days later i start to hear a faint hissing sound from the bay, i tried to locate it was it was too faint. recently it has gotten louder. to the point now where i am positive it is coming from the 4th injector (or is it first?) towards the drivers side.
also, not sure if it matters, but my idle used to be jumpy between 800-1200, now its strong at 2000 on start and stays at 1500…?
anyone have this issue before? any advice on how to proceed? im assuming pop off the fuel rail and go from there, ive just never done it b4.
and far as i can tell i have not lost much performance, not sure about gas milage. its never been great lol
thanks everyone
tRece
could really use a bit of guidance …anyone out there have any experience with this type of issue?
I would check the Injector “o” ring to see if it’s damaged. If it’s closest to the driver side then you are looking at injector # 1. Get a spray bottle and some soap water and spray it around the injector and see if the idle levels out. If there is a difference then you just have a small vacumm leak at the injector “o” ring. Im not sure how the exhaust would factor in on the “o” ring going out. Could just be a coincidence. I sounds like a vacumm leak from what you discribed. The sound was faint and you got little RPM differences an now you can really hear the leak and the RPM’s are higher now at a steady 2000 rpm. Check it out and if the ring is bad just replace it. Cheap and not very hard at all.
Ryan
