low heat?
i just bought a 92 integ and when i turn on the heat or a/c it only blows out at the lowest speed? why is this? it takes me 20 minutes in the morning to unfog my windows!!! please shed some light guys, thanks:confused:
Your fan switch is probably just dirty. You can get a contact clean for that. You can get it at any electronics supply store. Just pull the knob off the switch and spray it in there and turn the switch a bunch.
I am not positive that that is your problem, but it is the first place you should check.
Later,
BR
i’ll try that and see if it work!! i hope! thanks
