Lower control arm, lower arm bar ect
Ive looked around and couldnt find anything on this but will aftermarket DA lower control arm, rear sway bar, lower arm bar fit on a DB1?
Should be the same. DB1 is a Gs-r right?
No the GS-R is a DB2. A DB1 is the sedan
I dont see why not. Only difference i see is just the difference in how many doors and longer exhaust. If we can swap suspension from a 2 door to 4 door then it should bolt up the same.
ok cool thanks ive always looked for info on that but couldnt find it any where
Ive swapped them over no probs
